I have made an object in solidworks which looks like this:
I then decided to print this object out on my Ulltimaker 3D printer, so I exported the file as a .stl file, and did all the stuff in order to print it.
The problem is, the resulting print had visible polygons! How can I increase the number of polygons and get smoother results?
It's under the "options" button when you save as STL. You can vary the resolution, deviation and angle.
