Hello everyone!
I am having a very hard time converting the surface bodies in the attached piece to solid bodies.
I have read the attached thread here: Surface to Solid Feature?
Yet I think the mirroring in the included pieces is making it hard to convert these faces into solid bodies.
One of the problems is that the surface body is the result of a loft, so when I am trying to DELETE FACE on part of the loft, I have to delete it using a 3d face. In turn, the Knit command is not able to turn the faces into a knit.
How would you guys approach this? How am I approaching it in a incorrect manner?
I appreciate any help/advice.
Hi Nik,
Try rolling back before the mirror features, close both surfaces with planar faces and knit them, form two new solids from each surface, Mirror bodies and finally merge all bodies. let me know if you have any problems, hope this helps.
