VBA - SaveAs files dialog issue (IGES)
Question asked by Danniel Sims on Apr 27, 2016
Latest reply on Apr 27, 2016 by John Alexander
Okay, so I have a macro that I have to save me lots of time.  I have to save out component parts of an assembly to STEP, STL, IGES, and Parasolid filetypes for CADCAM software.  It turns off each part of the assembly and saves it out to specific folders, then it reassembles the output files to verify the new coordinate system is correct. Everything works except I get a pop-up that I can't seem to get rid of on the SAVEAS for the IGES files.  This was two macros I joined into one, so there may be now unused variables at the top of the code.
I have tried forcing the user preferences toggle to false, but it always comes out of the line as true.  The bad line was in Settings sub, but I tried moving it to directly above the saveas (highlighted in red).
I'm not sure what I'm doing wrong, or if it is my version.  I am using Solidworks 2007 (I know it's old, but it's what I'm stuck with).
If I can bypass this pop-up I can totally automate this with a push of a button.
Option Explicit
Dim swApp As Object
Dim Part As Object
Dim SubPart As Object
Dim SelMgr As Object
Dim swComp As Object
Dim swModel As Object
Dim swModelDocExt As Object
Dim swFeatMgr As Object
Dim count As Long
Dim featArr As Variant
Dim swModeler As Object
Dim boolstatus As Boolean
Dim Feature As Object
Dim swModelDoc As SldWorks.ModelDoc2
Dim nam, a, newdoc, loc, locsplit, cur_assembly, build, buildc, asmPath, asmFile, asmSplit
Dim doc_nam, doc_split, doc_count, doc_path, d
Dim t, obType, bRet, obnam, assemble, las, abbrev
Dim featnam, featl
Dim ms_x_t, ms_iges, ms_stl, ms_step
Public fso, f, f1, fc, fs, fs2, OCS, SetOCS, IGS, SetIGS, STL, SetSTL, i
Sub Settings()
Set swModeler = swApp.GetModeler
Set swModel = swApp.ActiveDoc
'IGES PREF
swApp.SetUserPreferenceToggle swIGESComponentsIntoOneFile, True
swApp.SetUserPreferenceToggle swIGESExportSolidAndSurface, True
swApp.SetUserPreferenceToggle swIGESFlattenAssemHierarchy, True
swApp.SetUserPreferenceToggle swIGESHighTrimCurveAccuracy, True
'STL PREF
swApp.SetUserPreferenceToggle swSTLComponentsIntoOneFile, True
swApp.SetUserPreferenceToggle swSTLShowInfoOnSave, False
swApp.SetUserPreferenceToggle swSTLBinaryFormat, True
swApp.SetUserPreferenceToggle swSTLComponentsIntoOneFile, False
swApp.SetUserPreferenceToggle swSTLDontTranslateToPositive, True
swApp.SetUserPreferenceToggle swSTLPreview, False
'PARASOLID PREF
swApp.SetUserPreferenceToggle swParasolidOutputVersion_160, True
swApp.SetUserPreferenceToggle swXTAssemSaveFormat, True
'STEP PREF
Sub ExitSettings()
'PARASOLID PREF
swApp.SetUserPreferenceToggle swParasolidOutputVersion_latest, True
swApp.SetUserPreferenceToggle swXTAssemSaveFormat, False
'STEP PREF
Sub Interference_3D_Save()
Set swModelDocExt = swModel.Extension
Set swFeatMgr = swModel.FeatureManager
count = swFeatMgr.GetFeatureCount(True)
featArr = swFeatMgr.GetFeatures(True)
Set SelMgr = swModel.SelectionManager
Dim starttime, endtime, ttime
Dim featnam, featl
Dim CADCAM
starttime = Now
'IS FILE OPEN?
If swModel Is Nothing Then
    Exit Sub
' SET USER PREFERENCES
Settings
'GET FILE PATH
doc_nam = swModel.GetPathName
doc_split = Split(doc_nam, "\")
doc_count = UBound(doc_split)
doc_path = ""
d = 0
Do Until d = doc_count
    doc_path = doc_path & doc_split(d) & "\"
d = d + 1
Loop
loc = doc_path
' CHECK IF FOLDERS EXIST - CREATE NEW IF FALSE
    Set fso = CreateObject("Scripting.FileSystemObject")
    If fso.FolderExists(doc_path & "IGS") = False Then
        fso.CreateFolder (doc_path & "IGS")
        fso.CreateFolder (doc_path & "IGS\SW")
    If fso.FolderExists(doc_path & "STEP") = False Then
        fso.CreateFolder (doc_path & "STEP")
        fso.CreateFolder (doc_path & "STEP\SW")
    If fso.FolderExists(doc_path & "STL") = False Then
        fso.CreateFolder (doc_path & "STL")
        fso.CreateFolder (doc_path & "STL\SW")
    If fso.FolderExists(doc_path & "x_t") = False Then
        fso.CreateFolder (doc_path & "x_t")
        fso.CreateFolder (doc_path & "x_t\SW")
'GET COORDINATE SYSTEM NAME
i = 1
Do Until i = count
    If featArr(i).GetTypeName = "CoordSys" Then
        CADCAM = featArr(i).Name
        GoTo HideStep
i = i + 1
Loop
MsgBox "There is no Coordinate System added to this assembly.", vbCritical
Exit Sub
'HIDE ALL COMPONENTS BETWEEN ORIGIN AND MATES
HideStep:
i = 1
Do Until i = count
    If featArr(i).GetTypeName = "MateGroup" Then
        Exit Do
    Else
        If featArr(i).GetTypeName = "OriginProfileFeature" Then
            i = i + 1
            Do Until featArr(i).GetTypeName = "MateGroup"
                assemble = doc_split(UBound(doc_split))
                las = Len(assemble) - 7
                abbrev = Left(assemble, las)
                obnam = featArr(i).Name & "@" & abbrev
                bRet = swModel.Extension.SelectByID2(obnam, "COMPONENT", 0, 0, 0, False, 0, Nothing, 0)
                swModel.HideComponent2
            i = i + 1
            Loop
i = i + 1
Loop
' UNHIDE EACH ASSEMBLY AND SAVE AS EACH FILETYPE IN EACH APPROPRIATE FOLDER
i = 1
Do Until i = count
        Exit Do
    Else
            i = i + 1
                swModel.ShowComponent2
                featl = Len(featArr(i).Name) - 2
                featnam = Left(featArr(i).Name, featl)
                'X_T
                'SET COORDINATE POSITION
                OCS = swModel.GetUserPreferenceStringValue(swFileSaveAsCoordinateSystem)
                'Debug.Print , OCS
                swModel.SetUserPreferenceStringValue swFileSaveAsCoordinateSystem, CADCAM
                swModel.SaveAs2 doc_path & "x_t\" & featnam & ".X_T", 0, True, False
                swModel.SaveAs2 doc_path & "x_t\SW\" & featnam & "_XT.X_T", 0, True, False
                'IGS
                'Debug.Print , OCS
                'swApp.SetUserPreferenceToggle swIGESComponentsIntoOneFile, False
                swModel.SaveAs2 doc_path & "IGS\" & featnam & ".IGS", 0, True, True
                swModel.SaveAs2 doc_path & "IGS\SW\" & featnam & "_IGS.IGS", 0, True, True
                'STL
                'Debug.Print , OCS
                swModel.SaveAs2 doc_path & "STL\" & featnam & ".STL", 0, True, False
                swModel.SaveAs2 doc_path & "STL\SW\" & featnam & "_STL.STL", 0, True, False
                'STEP
                'Debug.Print , OCS
                swModel.SaveAs2 doc_path & "STEP\" & featnam & ".STEP", 0, True, False
                swModel.SaveAs2 doc_path & "STEP\SW\" & featnam & "_STP.STEP", 0, True, False
                 'REHIDE COMPONENT - GET NEXT
             i = i + 1
            Loop
i = i + 1
Loop
i = 1
Do Until i = count
        Exit Do
    Else
            i = i + 1
            i = i + 1
            Loop
i = i + 1
Loop
'RESTORE PARASOLID SETTINGS TO NORMAL
ExitSettings
'BEGIN ASSEMBLY PROCESS
Assemble_3D
endtime = Now
ttime = DateDiff("s", starttime, endtime)
MsgBox "FILES SAVED IN " & ttime & " SECONDS!"
Sub Assemble_3D()
newdoc = "G:\SolidWorks\Design\SW2004\Templates\asm\Assembly.asmdot"
locsplit = Split(loc, "\")
a = UBound(locsplit) - 1
buildc = 0
Do Until buildc = 4 ' testing =1, normal =4
    If buildc = 0 Then
        build = "IGS"
    Else
        If buildc = 1 Then
            build = "STEP"
        Else
            If buildc = 2 Then
                build = "STL"
            Else
                If buildc = 3 Then
                    build = "x_t"
                Else
                    MsgBox "Bad count!", vbCritical
                    Exit Do
    Set Part = swApp.NewDocument(newdoc, 0, 0#, 0#)
    Part.SaveAs2 loc & build & "\SW\" & locsplit(a) & "_" & build & ".SLDASM", 0, False, False
    Set Part = swApp.ActiveDoc
    cur_assembly = locsplit(a) & "_" & build & ".SLDASM"
    asmPath = loc & build & "\SW\*" & build
    asmFile = Dir(asmPath)
    Do While asmFile <> ""
        asmSplit = Split(asmFile, ".")
        swApp.LoadFile2 loc & build & "\SW\" & asmFile, ""
        Set SubPart = swApp.ActiveDoc
        If build = "STL" Then
            SubPart.SaveAs2 loc & build & "\SW\" & asmSplit(0) & ".SLDPRT", 0, False, False
        Else
            SubPart.SaveAs2 loc & build & "\SW\" & asmSplit(0) & ".SLDASM", 0, False, False
        'Set SubPart = swApp.ActiveDoc
            Set SelMgr = Part.SelectionManager
            Part.AddComponent loc & build & "\SW\" & asmSplit(0) & ".SLDPRT", 0, 0, 0
            Part.ClearSelection2 True
            boolstatus = Part.EditRebuild3
            boolstatus = Part.SetUserPreferenceToggle(198, True)
            Part.ViewZoomtofit2
            swApp.CloseDoc asmSplit(0) & ".SLDPRT"
        Else
            Part.AddComponent loc & build & "\SW\" & asmSplit(0) & ".SLDASM", 0, 0, 0
            Part.ViewZoomtofit2
            swApp.CloseDoc asmSplit(0) & ".SLDASM"
        Part.ShowNamedView2 "*Isometric", 7
    asmFile = Dir()
    Loop
'START MATE PROCESS LOOP HERE
'GET FILE PATH
doc_path = ""
d = 0
d = d + 1
Loop
i = 1
Do Until i = count
        Exit Do
    Else
            i = i + 1
                'GoTo filpath
                swModel.UnfixComponent
                boolstatus = Part.Extension.SelectByID2("Right Plane", "PLANE", 0, 0, 0, False, 0, Nothing, 0)
                boolstatus = Part.Extension.SelectByID2("Right Plane@" & obnam, "PLANE", 0, 0, 0, True, 0, Nothing, 0)
                Set Feature = Part.AddMate3(swMateCOINCIDENT, swMateAlignALIGNED, False, 0, 0, 0, 0, 0, 0, 0, 0, False, longstatus)
                boolstatus = Part.Extension.SelectByID2("Front Plane", "PLANE", 0, 0, 0, False, 0, Nothing, 0)
                boolstatus = Part.Extension.SelectByID2("Front Plane@" & obnam, "PLANE", 0, 0, 0, True, 0, Nothing, 0)
                boolstatus = Part.Extension.SelectByID2("Top Plane", "PLANE", 0, 0, 0, False, 0, Nothing, 0)
                boolstatus = Part.Extension.SelectByID2("Top Plane@" & obnam, "PLANE", 0, 0, 0, True, 0, Nothing, 0)
                Part.ViewZoomtofit2
            i = i + 1
            Loop
i = i + 1
Loop
buildc = buildc + 1
Loop
swApp.ArrangeWindows 2
