I'm using the eDrawings Model Viewer, and I heard that the eDrawings Professional edition could be used to view step (or stp) files. However, when I tried this on a machine with eDrawings Professional, I got an error message "You need the full version of eDrawings to perform this function".
So I wonder... is the eDrawings Model Viewer (the registered ActiveX control) the same thing when you have eDrawings Professional on your machine?
Should I be able to use eDrawings Professional to open .step files in the first place??
Thanks in advance!
Groetjes, Bob Swart
Hello Bob, eDrawings does not support opening of STEP files. However if you do a Google search for eDrawings RapidFire, there is a free viewer you can download which will allow you to open STEP files.
Kind regards,
Prasad
