I have imported a DWG file into a sketch in a new part file. The problem is, the sketch has a ton of tiny sketch segments which it says are invalid geometry. Is there any easy way to select all these segments and delete them, instead of having to click each one individually?
Edit: The invalid geometries are scattered randomly throughout the sketch, and are too small to be seen unless I'm zoomed in pretty far, so it's just difficult to find them all
You can select multiple sketch elements with a click and drag box. Will that help?
