Hi
I'm trying to create a pattern on the surface of a part. I can extrude cut and pattern but the pattern is created with a separate file and production process so I don't want it on the part file, plus it slows my computer. I remember seeing a method for creating a surface pattern at some point but haven't been able to find it. Can someone direct me to it?
Thank you,
GArnet
Welcome to the forum. It may be difficult to answer without more information, but have you considered creating a second configuration of the Part, with the extrude cut and pattern suppressed on one of them? If you load that configuration when you don't need to show the feature it should speed things up.
