I recently had problems with my hard disk, lost some folders and Solidworks wasn't able to run properly. I desinstalled SolidWorks specifying I wanted to reinstall it later on the same computer. Now, when I try to install it, the installer can't find the folder "C:\SOLIDWORKS Data\.", wich is where the toolbox was located prior to my problems. That folder does not exist anymore, and I can't find a way to specify to the installer to create a new one from scratch instead of re-using the old one.
Is there a way to solve this issue?
Try creating the folder manually and try again.
Also are you using administrative image to install OR directly installing from the installation manager?
