I have been looking for a way to make a Linear Pattern but not have the same repeating dimension for each instance. I often have to make repeating tabs or holes that are in-line with each other. But the dimensions from center to center are not a "pattern". Making a linear pattern and getting to choose the distance per instance from the seed or datum would be ideal.
Is there a way to do this?
Option "Sketch driven pattern" may help you.
