Is it possible to output the Equation Manager to include the "Evaluates to" column. When exporting, everything except the mathematical results end up in the .txt file. There are (20) global variables, (17) of which are equations. I need to compare several versions of them to try & figure out why my model is behaving unexpectedly. Thanks.
You could press ctrl-Print Screen and capture the equation manager dialog - as long as you just need a visual and not the actual number data.
Daen
