2 Replies Latest reply on Apr 26, 2016 10:36 AM by Joe Pickens
    API To find hole locations on imported parts
    Joe Pickens
      In short what I am doing is taking two imported parts and aline the holes and mating them.
      the macro i am trying to wright would locate and make an array of hole locations of both parts so i can use the array to find the set of holes that match up.
      the issue that i am running into is that i can figure out a way to get the hole centers and axis direction and hole diameter from the part
      i am currently using the iface2 with GetFirstFace and GetNextFace to try to pull the info i want but i cant figure out how to get the info i need from that member
        • Re: API To find hole locations on imported parts
          Michael Spens
          Hi Joe,
               I'll make some assumptions from your message.  If you already have interfaces to Face2, use GetEdges.  This also assumes you're getting the faces from an assembly Component2 interface.
          'vb.net, SelFace is a Face2 interface, Comp is a Component2 interface...
          Dim FaceEdges() As Object = SelFace.GetEdges
          For Each MyEdge As Edge In FaceEdges
          If IsFullCircle(MyEdge) Then
          Dim MyCurve as Curve
          MyCurve = MyEdge.GetCurve()
          Dim center() as Double
          center = GetCircleCenter(MyCurve, Comp, swApp)
          'do something with the center
          End For
          'function to check if an edge is a full circle
          Private Function IsFullCircle(ByVal EdgeToCheck As Edge) As Boolean
          Dim MyCurve As Curve = EdgeToCheck.GetCurve
          If MyCurve.IsCircle Then
          'you have a circular edge
          'is it a complete circle?
          If EdgeToCheck.GetStartVertex() Is Nothing Then
          'full circle
          Return True
          Exit Function
          Return False
          End Function
          'return an array of doubles for the x, y, z circle center
          'relative to the assembly
          Private Function GetCircleCenter(ByVal MyCurve As Curve, _
          ByVal Comp As Component2, _
          ByVal swApp As SldWorks) As Double()
          Dim MyCenter(2) As Double
          Dim returnValues As Object = MyCurve.CircleParams
          MyCenter(0) = returnValues(0)
          MyCenter(1) = returnValues(1)
          MyCenter(2) = returnValues(2)
          'returnValues(3-5) represent the axis x, y, and z
          'returnValues(6) represents the radius
          Dim Radius As Double = returnValues(6)
          Dim MathUtil As MathUtility = swApp.GetMathUtility
          Dim mPoint As MathPoint = Nothing
          mPoint = MathUtil.CreatePoint(MyCenter)
          Dim CompTransform As MathTransform = Comp.Transform2
          mPoint = mPoint.MultiplyTransform(CompTransform)
          'return the x,y,z location in assembly space
          Return mPoint.ArrayData
          End Function
