Hi, Can the Right-Click Menu in Vault View be modified without removing programs. I would like to move the most used "Change State" higher up to minimize mouse movement. Thanks.
In the admin tool, right click on a user or group and select 'Settings'. Then select 'Menus' on the left. You can modify the right click selections as well as the toolbar menus. Once you get one user setup, you can copy the setting to other users. It's best to do this at the group level which will apply the settings to all users in the group.
