2 Replies Latest reply on May 6, 2016 10:56 PM by Sanya Shmidt
    How to get a solidbody object from an array based on the description from ComboBox?
    Sanya Shmidt
      Hello Guys!
      Below is the code I`m using to get a list of solidbodies. I`m adding Structural Members only into my Combobox.
      I need to show that body on the drawing when user chooses it from drop down list. I`m having problems referencing solidbodies from the array based on user choice.
      Can someone point me into the right direction please?
      Alex.
      Option Explicit
      Dim swView As SldWorks.View
      Dim nbrBodies As Long
      Dim arrBody As Variant
      Dim swBody As SldWorks.Body2
      Dim swFace As SldWorks.Face2
      Dim swEnt As SldWorks.Entity
      Dim swSelData As SldWorks.SelectData
      Dim bool As Boolean
      Dim arrBodiesIn As Variant
      Dim Bodies(0) As Object
      Dim i As Long
      Dim objType As Long
      Set swApp = GetObject(, "SldWorks.Application")
      Set swModel = swApp.ActiveDoc
      Set swView = swSelMgr.GetSelectedObject6(1, -1)
      If (swView Is Nothing) Then
          MsgBox "View not selected."
          Exit Sub
      nbrBodies = swView.GetBodiesCount
          Debug.Print "Number of bodies: " & nbrBodies
          If (nbrBodies < 1) Then
              MsgBox "No bodies in selected view."
              Exit Sub
      arrBody = swView.Bodies
      For i = 0 To UBound(arrBody)
          Set swBody = arrBody(i)
          Set swSelData = swSelMgr.CreateSelectData
          swSelData.View = swView
          bool = swBody.Select2(False, swSelData)
              ' Object type 76 is a solid body
              objType = swSelMgr.GetSelectedObjectType3(1, -1)
      '        If (objType = 76) Then
      '            Debug.Print " Object type: solid body"
      '        End If
              If (Not (swSelSOLIDBODIES = swSelMgr.GetSelectedObjectType3(1, -1))) Then
                  MsgBox "Solid body not found."
              Set swFace = swBody.GetFirstFace
              Do While Not swFace Is Nothing
                  Set swEnt = swFace
                  ' Select using IEntity
                  bool = swEnt.Select4(True, swSelData): Debug.Assert bool
                  Set swFace = swFace.GetNextFace
              Loop
              Debug.Print "   Name of body: " & swBody.GetSelectionId
          ' adding Descriptions on to the combo box
          With frm_main.ComboBox_Bodies
              If Mid(swBody.GetSelectionId, 1, 17) = "Structural Member" Then
                  .AddItem (swBody.GetSelectionId)
          End With
          Next i
      swModel.ClearSelection2 True
      So here when user chooses the Item from drop down I have to reference it and show:
      Private Sub ComboBox_Bodies_Change()
      ' Get the bodies from referenced model
      Set swModel = swView.ReferencedDocument
      arrBody = swModel.GetBodies2(swSolidBody, True)
      If (nbrBodies = 1) Then
         swView.Bodies = (arrBody)
      Else
         ' Set the body to view, HOW TO REFERENCE IT TO swBody.GetSelectionId AND MY COMBOBOX?
         Set Bodies(0) = arrBody(0)
         arrBodiesIn = Bodies
         swView.Bodies = (arrBodiesIn)
      Any help is appreciated
        • Re: How to get a solidbody object from an array based on the description from ComboBox?
          Michael Spens
          Cool idea Sanya!  Edit your form code like the following.  You may also need to make swView and Bodies both declared Public in your module.
          Dim swModel As ModelDoc2
          Else
             Set Bodies(0) = GetSpecificBody(ComboBox_Bodies.Text, swModel)
          Function GetSpecificBody(bodyName As String, swModel As ModelDoc2) As Body2
              Dim mBodies As Variant
              Dim part As PartDoc
              Set part = swModel
              mBodies = part.GetBodies2(swSolidBody, True)
              Dim b As Body2
              Dim i As Integer
              For i = 0 To UBound(mBodies)
                  Set b = mBodies(i)
                  If InStr(1, bodyName, b.Name, vbTextCompare) <> 0 Then
                      Set GetSpecificBody = b
                      Exit Function
              Next i
          End Function
