So I've got a part that has a horizontal and a vertical offset, I need 2 halves of a base bolt cover to go around a HSS column. I thought I was being clever and created a single part with 2 configurations using a single variable I called "Side Modifier" with 1 or -1. I multiplied my offset by the modifier, and the equations wouldn't change the direction of the offset. I don't know what my next step should be. Any help is very much appreciated. Using SW 2016
Okay, now that I understand what you are trying to do. Attached is my second try. It assumes positive x offset is to right and y positive offset is up when looking at top view. So in the case of your attached sketch x_offset = -3 and y_offset = 1.25 I did not change the width of the base plate to 23 as you have shown because it is not a factor in how I set up the equations (they should adjust to any length or width changes of the cover).
