Report Generator - SQL Query help?
Question asked by David Heverin on Apr 19, 2016
Latest reply on May 17, 2016 by Tim Webb
I have a SQL query (.crp file) that returns a file name, latest revision, workflow status and path.  I want to edit it to also return the latest revision date.  Can anyone look at query and help?
Here is the query:
/*******************    Enterprise Report      ********************/
@[GetFilenameAndRevision]
§Name [Show latest revision number for files]
§Company [SolidWorks]
§Description
[This report lists the latest revision number for files under selected folder.]
§Version [1.0]
§Arguments
ProjectID PID[1] [Select starting folder]
§Sql
Declare @FolderPath nvarchar(260)
Set @FolderPath = (Select Path from Projects where ProjectID = {PID});
WITH GetRevs AS
SELECT D.Filename, MAX(UR.Comment) AS Revision
FROM  RevGenCounters AS RGC INNER JOIN
      Documents AS D ON RGC.DocumentID = D.DocumentID INNER JOIN
      UserRevs AS UR ON D.DocumentID = UR.DocumentID
Group By D.Filename
Select GR.Filename, GR.Revision, S.Name AS [Workflow Status], P.Path AS [Folder Path]
FROM GetRevs AS GR INNER JOIN Documents AS D ON D.Filename = GR.Filename INNER JOIN
DocumentsInProjects AS DP ON DP.DocumentID = D.DocumentID INNER JOIN
Projects AS P ON P.ProjectID = DP.ProjectID INNER JOIN
Status AS S ON D.CurrentStatusID = S.StatusID
Where P.Path like @FolderPath + '%'
This is the report generated:
Thanks!!
