Hey guys,
I have a problem here, im trying a drop test simulation with this attached chassis and everything is fine except mesh, when I run mesh creation, solidworks show me some (a lot) of body interferences between most of the structural members.
If anyone can help , it will be much appreciated.
Thanks!
This is part of the GIGO problem that has plagued mankind since the dawn of time. If your geometry isn't "clean" then you have no hope of getting good information out even if you could run your FEA.
Go back and make sure that there are no gaps between parts; that the parts fit together perfectly (flat or lofted surfaces); make certain that you have cleaned things up so there will be no slivers.
