Im tyring to create a feature using the sweep command and guide curves. I have a profile that im extruding ~10mm from one end of the part. Id like the extruded profile to follow the edges of the current part by using guide curves. I cant seem to get it to work. I can sweep the profile along one edge but the other does not follow. Hopefully the part is attached.
I don't use Sweeps very often, but a simple fix would be to cut that body in half (keeping the good side, of course), then Mirror the body using the cut surface as the Mirror plane and selecting "Merge solids" in the Mirror PropertyManager.
