I have create a plane and want to split it to some small part, I tried to use Split tool. but it did not work. Every time it shows that Rebuild Error "Split feature failed". I do not know what should I do, can someone help?
You want to use the 'Split' feature NOT the 'Split Line'
Also, your fuselage is still a surface body, along with many other surface body's that should be solids.
Best, Jason
Best, Jason
