When starting a new drawing on my drawing template, if I select the Model View to place my first view, Solidworks crashes. If I use Standard 3 View to insert my first view it works just fine. If I use 3 view and then delete the three views, I can use Model View without an issue. Any ideas what would be causing it? I thought maybe it was an issue with my template properties, but if that was the case, would it not also crash when inserting a standard 3 view?
Thanks!
