Run macro on all open drawings
Question asked by Anton Miller on Apr 18, 2016
Latest reply on Apr 19, 2016 by Viktor Bovzdarenko
Is there a way to run a macro on all open drawings?
so lets say I open up 20 different drawings (could be different file locations), click the macro button and have it cycle through them all?  I tried to record this function and it always used the file name.  I'm assuming there is a way to do like what you would for a batch folder run macro, but I don't know how.
I wish to have the macro save each open drawing as a pdf file name being a custom property.  macro below.
'File Save As PDF
Dim swApp           As SldWorks.SldWorks
Dim swModel         As SldWorks.ModelDoc2
Dim swDraw          As SldWorks.DrawingDoc
Dim swCustProp      As CustomPropertyManager
Dim valOut          As String
Dim resolvedValOut  As String
Dim Filepath        As String
Dim FileName        As String
Set swDraw = swApp.ActiveDoc
If (swDraw Is Nothing) Or (swDraw.GetType <> swDocDRAWING) Then
swApp.SendMsgToUser ("To be used for drawings only, Open a drawing first and then TRY AGAIN!")
Exit Sub
Set swView = swDraw.GetFirstView
Set swView = swView.GetNextView
Set swModel = swView.ReferencedDocument
Set Sheet = swApp.ActiveDoc.GetCurrentSheet
Set swCustProp = swModel.Extension.CustomPropertyManager("")
swCustProp.Get2 "dwgnumber1", valOut, resolvedValOut 'Change the custom property name here
Filepath = Left(swDraw.GetPathName, InStrRev(swDraw.GetPathName, "\"))
FileName = Left(swDraw.GetTitle, Len(swDraw.GetTitle) - 9)
swDraw.SaveAs (Filepath + resolvedValOut + ".PDF") 'Change the custom property text here
