Curve through XYZ points does not update when reference txt file is updated
Question asked by Ben R. on Apr 17, 2016
Latest reply on Apr 20, 2016 by Sworks User
When rebuilding the model, the file isn't checked and the curve isn't updated.
I'm trying to make a wing with a single part file that can support multiple airfoils. The simplest method to make the wing seems to be to generate two XYZ curves and loft between the two. I can generate the curves with a program, and save them to the appropriate .txt files. The XYZ curves reference those files. Everything is linked appropriately, but I can't figure out a way to update the curves without clicking through 'edit feature,' browse, select the same file, etc.
Is there a "force total rebuild" or "reload references" command? Perhaps I'm trying to fit a square peg in a round hole and there's just a better way to do this? I'm still relatively new to solidworks.
Thanks in advance.
