Hello at all,
I use SW2016 and I have the following problem.
I have to create some easy product animations. Its not very compliacted, was also not necessary to insert a camera.
The problem is, that there are flickerings on the matt chrome surface in the final video after the rendering. When the surface turns around an axis for example some areas flickers. The backround is black and only the basic lights are activated.
The strange thing is that in other animations i did with the same specifications there are no flickering areas.
Maybe I can do an upload from a short sequence of the animation for a better understanding.
Thank you very much for your suggestions.
