I used one form tool. Then I try to use another form tool on
top of the first one. I can't seem to make it work.
Attached is the file, if anyone has time to try to make it work. There are both form tools unsuppressed, but only one of them will work at a time. Is there any way to have them both work?
Thanks.
Thanks.
That is the way it is... You can't do a form within a form. You are going to need to break up the edge forms so you are not forming across the entire face of your part to add your additional CS.
Can you put a hole through the middle of your box cover form tool. Not sure if that would work.
You may need to do the box cover shape as a solid, then shell. After that add your form tool CS's.
I have a few more ideas, but do not have time until later to try.
Cheers,
