3 Replies Latest reply on Apr 18, 2016 10:08 AM by roberto gennari
    How do I change a standard hole using the api?
    Scott L.
      I have a spreadsheet that changes dimensions of models.  I want to be able to select different standard holes from a list, manipulating the hole wizard, instead of just changing the dimensions.
      The hole is a feature on a model.  If I have the model open, it works wonderfully.  What I want to do is have the assembly open and change the feature without having to open the model.  Currently if I try running the program as is, the SelectByID2 command returns a false value.
      Thank you,
      Scott
