Dear all,
I'm quite new into VBA, and am looking for a solution to run a pack and go from a macro.
Pack and go macro -->without old number
I found this macro, which works quite well, but i would like to adapt it a bit.
Is it possible to pack and go to the current save folder? (Eventually add a new folder to this folder, in which the pack and go'd files will be saved)
Is it possible to give each file their original name, with a pre- or suffix, taken out of the top level assembly properties? (For example customer/project name)
And, is it possible to give a specific sub-folder structure? I'm used to make a folder hierarchy like shown in the picture below.
So, a projectfolder, which contains separate folders for each 'type of file', and the top-level assemby directly in it.
I'm willing to learn some vba/api offcourse, and am looking forward to your help.
Best regards,
Arno
Get the current folder and set that as sOutputPath. And then
If Dir(strOutputPath & "\" & "Folder Name Here", vbDirectory) = "" Then
MkDir strOutputPath & "\" & "Folder Name Here"
sOutputPath = strOutputPath & "\" & "Folder Name Here"
Check this post: Macro Help: Pack and go With drawings and change name to property
I think yes this can be done. You can set the output path accordingly based on file extension OR if you've the current files in same structure then using
swPackAndGo.FlattenToSingleFolder = False
Also check this example for related answers Pack and Go an Assembly (VBA)
