In an assembly, if you do a component pattern, say 7 components, is it possible to have the middle component be a different one somehow?
I've got one rod, evenly spaced 7 times using component pattern. But the middle rod needs to be a shorter length one.
There is no "replace component" available for the parts patterned
And "skip instance" will also skip the other 4 things I'm patterning at the same time.
What about using configurations? Each instance of the pattern can use a different configuration than the seed.
