Hi guys, I'm trying to do swept cut with several spline lines I drew (like splitting tunnels effect). Any reason why it doesn't work?
File attached
File attached
Use the "Split" feature instead. Remember to press "Cut bodies" and select (check mark) all the resulting bodies.
it's a zero thickness issue,...change your 1.5 dia profile to 1.49...
personally, I'd do it differently though.. using surfaces, trim mutual and surface cut (or solid and combine/subtract).. so you can see and make sure the paths/cut look correct.
