How to speed up the insertion/deletion of bom?
Question asked by Sanya Shmidt on Apr 12, 2016
Morning guys!
I`m working on the huge assembly with 10 configurations. I`m trying to activate every configuration and get the BOM, save it to Excel, go to next configuration and so on....
Below is the code:  The problem I`m having is - that it takes ~12-15 seconds for the BOM to show up on the drawing and then disappear ....I`m wondering if there is another way or approach to do that? Can the model be hidden ?(Like in Excel where you can hide application and disable screen updating)
Sub InsertBOM()
   Set swModel = swApp.ActiveDoc
   Set swDraw = swModel
   Set swView = swDraw.GetCurrentSheet.GetViews()(0) 'Set swView = swDraw.GetFirstView
   'Inserting BOM Table
  AnchorType = SwConst.swBOMConfigurationAnchorType_e.swBOMConfigurationAnchor_TopRight
  bomType = SwConst.swBomType_e.swBomType_Indented
  Configuration = "Default"
  tableTemplate = "C:\TestVaul\BOM.sldbomtbt"
   Set swBomAnn = swView.InsertBomTable4(True, 0, 0, AnchorType, bomType, Configuration, tableTemplate, False, swNumberingType_Detailed, True) ' true - ise anchor point
   Set swBomFeat = swBomAnn.BomFeature
  swBomFeat.KeepMissingItems = False
   ' selecting the table
   Set swFeat = swModel.FirstFeature
   Do While Not swFeat Is Nothing
   If swFeat.GetTypeName = "BomFeat" Then
  swFeat.Select (False)
   Set swBomFeat = swFeat.GetSpecificFeature2
  vTables = swBomFeat.GetTableAnnotations
   Set swBomTable = vTables(0)
   Set swFeat = swFeat.GetNextFeature
   Loop
   ' making sure Array is big enough to fit all data
   ReDim BOMArray(0 To swBomTable.RowCount - 1, 0 To swBomTable.ColumnCount - 1)
   ' reading data from BOM on the drawing into 2d-Array
   For i = 0 To swBomTable.RowCount - 1
   For j = 0 To swBomTable.ColumnCount - 1
  BOMArray(i, j) = swBomTable.DisplayedText(i, j)
   Next j
   Next i
   'Work with BomFeature to get and set configurations
   'All valid configurations are saved now in array Names()
   Set swBomFeat = swBomTable.BomFeature
  Names = swBomFeat.GetConfigurations(False, Visible)
  Visible(0) = True
  boolStatus = swBomFeat.SetConfigurations(True, Visible, Names)
   ' removing BOM from the model
  swModel.EditDelete
