Delete block from only one sheet
Question asked by Eimantas Palevicius on Apr 12, 2016
Latest reply on Dec 21, 2016 by Eimantas Palevicius
I am using this part of the code to delete all blocks in my selected drawing view. but when i run this code it also deletes blocks with the same name in other drawing views even in other sheets. Lets say i need to delete "block1" from "drawing view1" in "sheet2", but when i run this code it also deletes "block1" from "sheet1" "drawing view3". Any suggestions what i am doing wrong?
Set swSketchMgr = swModel.SketchManager
    vBlockDef = swSketchMgr.GetSketchBlockDefinitions
    If Not IsEmpty(vBlockDef) Then
        For i = 0 To UBound(vBlockDef)
            Set swBlockDef = vBlockDef(i)
            Set swFeat = swBlockDef.GetFeature
            retval = swFeat.Select2(False, -1)
            retval = swModelDocExt.DeleteSelection2(False)
        Next i
Regards
E.P.
Update. Found the correct code.
