Is there a way to have a note in a drawing show the name of a sketch to which it is pointing?
In other words: I have a part file with about a hundred sketches, each a circle. Each sketch was named to identify the location indicated by the circle. If this sketch is showing in a drawing, how can I have a note which will automatically show me the name of the circle- that is, the name of the sketch?
If they're set up as dims for the holes in the part, then you can use Model Items to add them to the drawing.
Also, if the notes are in an annotation view in the part, then I believe you can bring the annotation view into the drawing.
See SW help for more info.
Cheers,
Kevin
