API to get specific digit from file name.
Question asked by jason kooken on Apr 7, 2016
Latest reply on Jul 1, 2016 by Solid Air
I have a part numbering system that has the drawing rev built into the filename for example: 11111234A-PM.slddrw
Previously the Macro used to save this drawing would get the revision from custom properties.
This field is no longer updated and there is now a need to retrieve the revision from the filename instead.
Below is a clip of the current macro, in the "get revision" section is what was used to get the rev, I want to get the revision from the 9th digit of the file name as "rev"
any help would be greatly appreciated.
    Set Part = swApp.ActiveDoc
    Set swModel = swApp.ActiveDoc
    Set SelMgr = Part.SelectionManager
    Dim proj As String
    Dim dwg As String
    Dim filename As String
    Dim saveLoc As String
    Dim lastTwoChar As String
    Dim rev As String
    Dim trueRev As String
    Set swCusPropMgr = swModel.Extension.CustomPropertyManager("")
    filename = swModel.GetPathName
    If filename = "" Then
        MsgBox "Please save the file first and try again", vbCritical
        End
    'Get Revision
    retval = swCusPropMgr.Get3("Revision", False, rev, trueRev)
    If rev = "-" Then
        rev = "-"
