Hi, it's the first time that write in this forum...and is the
firsttime that install Solidwork from administrative image...I
thinkthat i've read all documentation and post but i have a
smalldoubt.
Suppose that i use a simple pc (with Windows XP SP2) for create anddeploy to clients the administrative image of SW2007 SP4.0, ok nowmy clients use SW2007 SP4.0 happily.....
I want update to SP5.0...., ok it's very simple, update onlyadministrative image and when client start solidwork automaticallyupdate to SP5.0, but there is a little problem, meanwhile i'vechange my pc...
ok i can recreate the administrative image but my clients don'tupdates automatically....
Now i must change the first administrative path with the new pathto the clients, there is a registry key for this ?
How can I solve this problem
best regard
best regard
The ID number *might* be different - I don't know enough about how the registry is organised to comment on that. Suffice to say the the ID was the same on all the clients here that had been installed from the admin image.
Look under 'InstallProperties' and you should see a key for 'InstallSource' - this is the one to change.
Regards
Martin
