I am working on a project where I am trying to space filleted divots around a sphere using curve fit under linear fit. I created a circular line that goes around the circumference of the sphere that I am using as a base for the curve fit but every time I try to solidify the fillets which it shows evenly spaced around the sphere it gives me an error saying to decrease the distance or number of fillets I am trying to mirror. I am not sure why it is doing this but need to have it done for a project. Also if it is possible for me to place 100 evenly placed fillets around the entire sphere, that would greatly speed up the project (not in a straight line around the sphere but 100 evenly spaced around the spheres total surface. Below I will attach the model I am working on. Thank you to anyone who can help I really appreciate it
What happened to the dimension on Sketch1?
The line isn't constrained to the origin either.
I recommend backing up a bit and mastering a simple sketch first.
Rather than Extrude and Fillet, I would probably use a simple Revolve-Cut instead.
No extra work plane needed.
