SPS. P.06/04/2016
Hey guys, this is my first time using forums and macros. I was looking at how to switch multiple sheet names and adjust the title in the sheet format. I got the macro to work for the sheets but I can't get the macro for the title. I want to switch whatever text is in the title to "ABC 10 x i" where i changes on each drawing sheet. The sheet follows the same concept where it is just the latter part "10 x i" and i got that to work using:
Dim swApp                   As Object
Dim swSheet                 As SldWorks.Sheet
Dim swDraw                  As SldWorks.DrawingDoc
Dim vSheetNames             As Variant
Dim i                       As Long
UserForm1.ListBox1.Clear
Set swDraw = swApp.ActiveDoc
Set swSheet = swDraw.GetCurrentSheet
vSheetNames = swDraw.GetSheetNames
    For i = 0 To UBound(vSheetNames)
       swDraw.ActivateSheet (vSheetNames(i))
       swSheet.SetName "10 X " & (0 + i * 5)
    Next i
    swDraw.ActivateSheet (vSheetNames(0))
    MsgBox ("Complete")
This is not my code. I just edited it on a forum I found here. Now I want to use that same for loop configuration and change the title block for each drawing sheet except I'm having trouble getting there. I can understand the coding a little bit but I'm new to these SW classes (or commands), so I don't know how to recall specifically, the title block.
I was using this code below except I don't want to change other stuff in the sheet format, just the title. If it's easier, I have the description for the part already entered in the property configuration manager and this is exactly what I want in the title. So it would be a string in front of the part description. Sorry I should have clarified this earlier but each drawing sheet is a different part configuration so I would like "ABC (part description)" on each drawing sheet title. I'm going to be away from the desk so I may not respond till 3/4 hours later but I would greatly appreciate any help.
' Preconditions: SolidWorks document is open and has a note
'            containing the text string "abc".
' Postconditions: The text string "abc" is replaced with
'             the text string "def".
Option Explicit
Dim swApp   As SldWorks.SldWorks
Dim swView  As SldWorks.View
Dim swNote  As SldWorks.Note
Dim strNoteText As String
Const strReplaceTextAs String = "abc"
Const strNewText    As String = "def"
    Set swModel = swApp.ActiveDoc
    Set swDraw = swModel
    Set swView = swDraw.GetFirstView
    Set swNote = swView.GetFirstNote
    While Not swNote Is Nothing
        strNoteText = swNote.GetText
        strNoteText = Replace(strNoteText, strReplaceText, strNewText, 1, -1, vbTextCompare)
        swNote.SetText strNoteText
        swModel.WindowRedraw
        Set swNote = swNote.GetNext
    Wend
