I'm just getting into SW 2D, and am attempting to create some sheet formats.
I can get a title block added in, and that saves just fine.
However, when I change the Doc Properties in Options, those will not save into my new format.
If I save as a template, it keeps the properties. If I use that same template file and save as a format, it converts those properties back to default.
If I save as a DRW, then try to save as a format, it converts the properties back to default.
What's happening here, and how can I fix it?
Sheet format does not save document properties, those are controlled by template.
However you can export drafting standard and then you can apply those to files as required.
