I have a complicated, swiss cheese area on an aluminum housing and would like to show a blown up view of that area with the dimensions coming from 0,0. Any way to make that happen in Solidworks? PRO/E it was dimension in the parent view, right click move to detail view. Time consuming but it at least would work. Ctrl+shift does not move dimensions from view to view for me.
John - I just did a quick mock up - and it may not be what you want, but you would need multiple drawing sheets, personally I would do one zone per sheet, blow it up so that the dimensions don't overcrowd the hole details etc. - however I know what I would have to deal with here, especially if the shop guys aren't used to it.
Now if you think you'll have more of this type of work then it might be good to get the guys trained for Hole Tables....
