Attached is a picture of a surface loft with guide curves.
Ofcourse the curvy spline and straight spline will have
differentparameters, but I am curious as how SW determines the
parameters ofthe created surface. Why do the isoparams slant
downwardinstead of going straight across? I have tried many
differentways, but it always ends up the same. The only thing
thatseems to make a difference is to add another profile curve (
theshort direction in this example).
*Edit: Actually, I take that back, because those lines go"across" the loft, not "with" the loft, theywon't tell you what you want to know.... You can force pointsby using sketches for guide curves (it looks like you are usingsurface edges), and creating splits in the line; although I don'tknow what benefit that would have. You could also use splitline on the surface to create the same points, but that's evenworse...
