I have Design Library including all kind of category sub-folders using for workgroup PDM
How can I add the these Design Library folders to PDM standard Vault?
I don't have migration tool and believe it's only available from VAR
What I want is to check in all the standard parts (no revision control) to Vault but instead of check in file by file, I want to move whole folders into the vault as PDM workgroup bulk check in
Drag your design library folder into ePDM where you want it, right click the top folder and select check-in. You can check-in folders and sub-folders of files all at once.
So the folders are automatically saved to the Vault, but files are not and you have to check files in?
Am I correct?
as I read from help
"You can use standard Windows techniques to move files and folders into the vault"
Correct, folders do not have to be checked in, they are added automatically. You can right click on a folder and select "Check-in" but all its doing is finding all checked out files underneath it and its sub-folders and checking them in.
