Hi Guys ,
I know that currently the VR from SolidWorks Visualize Pro does not work natively with Internet Explorer , which is a pretty big deal for any website that has some level of IE traffic....so all of them.
that being said I am wondering if anyone has been able to find a work around for the IE issue or if this issue is being fixed in a future SP or release?
Hi Husein,
Visualize create folder named “Images” with capital “I” for VR output images:
but javascript threesixty.js (from the folder "js") contain the link to the folder “images” with lower-case “i”:
so you can change the folder name or correct javascript threesixty.js
Doesn't matter which one you change, the point is they have to match each other.
The issue appears only when you use VR outputs outside the desktop environment as Windows is not case-sensitive.
Soon this will be fixed in code, for a while I recommend this workaround...
