Hello, I'd like to draw a helix-like version of a 2D sketch I made (will be a part of a screw-compressor), however I can't find any command that does extruding and rotating at the same time.
First file is what the result should be, second file is the 2D sketch.
Or pictures: imgur.com/a/hFCJu
Thanks in advance!
you have to make a helix to be the path for the rotation, then sweep your sketch along that path.
