how can I mirror a feature and delete original? (right/left)
thanx
thanx
Hi Greg,
Hum, that's an interesting request because there is not way to do it easily; reason being is because the mirror is dependent on the feature being mirrored. If you are mirroring a body, then you can create a "Delete Body" feature after your mirror, but if it is truly mirroring a feature which assumes that you are mirroring geometry in a single body, there is not way to do it other that perhaps using "Delete Face" to delete the original features faces from the body - but that isn't going to work for all cases.
Mark
I have the same 'issue' : I have an extrusion profile (for a door) that has all kinds of features added depending on position and function of the part in question.
The different parts are configurations of the base part (extrusion profile), governed by a design table.
The problem is that the 'Delete Base' refers to a body with features. But this changes as the mirror is at the end of the feature tree. At the rebuild I get errors at certain configurations and need to check the 'Delete Base' feature for the individual configurations. With a few configurations this is not a problem but if I make all possibilities in the design table I end up with more than 200 configurations. And I don't want to check them individually.
The 'Mirror Part' is not an option because I get too many parts to mirror individually.
Has anybody faced the same issue and found a working system that rebuilds ok?
Autodesk Inventor has the option to delete the base in the mirror function so it is not impossible...only not (yet) in SW.
Can you attach the file here?
My first thought is Delete and Patch, but there might be easier way.
