I am trying to make a Y pipe. Two connected at a 90 degree angle and the other is connected at 135 degrees. An online tutorial showed this using a surface loft to connect each of the 3 pipes. In the tutorial they can connect 2 pipes by surface lofting one edge of a pipe with another edge. When i try to loft 2 pipes together, a loft brings both pipes together completely, instead of just one edge and this does not allow me to connect all 3 pipes. Im new to SW but really appreciate anyone's help!
Kelly,.. see if this helps.. they were created back in 2008 but should do...
