I just started using solidworks a few days ago. I need help in combining 2 different surfaces together. I've attached a picture to this post.
Thanks in advance!
Thanks in advance!
Hi Denis,
to get one smooth surface (one face) in the sketch which is in "surface extrude 1" use the "fit spline" command:
2015 SOLIDWORKS Help - Fit Splines:
It will interpolate the lines and arks to a spline.
the extruded sketch will then create one smooth surface (one face) from entities which you have in the sketch.
Leszek
Dennis, welcome to the SW User family and forum.
You only have one surface body, those 'edges' are the tangent edges where profiles change.
May I recommend, work with solids and use surfaces as construction geometry to build solids.
Best, Jason E.
