Hi guys,
I'd like to know if there is a way to "show hidden lines" of a component , or components, but only the outer lines you would see if the part were to be fully visible. To clarify, I do not want to show hidden lines for any internals or features on the back side of the component.
Example below, a straight pipe running into a box (third angle projection). I want to show the outside profile of the pipe to show how deep it goes into the box but I don't need to show the lines for the Inside Diameter of the pipe (circled red).
Thanks in advance.
Sorry that is not possible directly but you can select those lines and hide them.
