Setting PLC circuit direction
Question asked by Brad Jordan on Mar 28, 2016
Latest reply on Mar 31, 2016 by Brad Jordan
I'm trying to setup some standard default PLC drawing configuration settings and the Circuit direction setting doesn't seem to be working properly.  I go into the PLC drawing configuration menu and set the direction to "Right" for a PLC Digital Input:
The drawing example pane above shows the card on the right side of the drawing with the terminals on the left.  When I try to insert the PLC card into a drawing it inserts with the terminals on the right, backwards from the setting:
The PLC card is classified as a Digital PLC input type.  The configuration selection is set to the configuration I modified.  Can't figure this one out.  Maybe it's not supposed to do this at all, dunno...
I know I can just invert the terminals easy enough, but I thought setting the direction of the circuit type would set the way the card terminals are inserted.
