As I sketch, my dimension input value is correct, but when shown on my sketch, it appears as though the dimension is scaled down. Nothing changes, just the value appears to be wrong. Example, i create a horizontal line with a dimension of 7". after hitting enter, the dimension will change to something like .08, but the length of the line is still 7", anyone else have the same problem
Carlos,
Are you adding the " after you type 7? If you are what is potentially happening is that your units are setup to a different default unit than inches. You can force a dimension to a specific amount by adding the units as you type but when you go to measure it again it will have auto-converted in the display but will actually be 7"
~Eric
