Design table not updating with VBA opened Excel Workbook
Question asked by Mike Smith on Mar 25, 2016
I have a part with an internal design table and the cells in said design table reference an external Excel spreadsheet. I have a macro that will open the design table and update the links. One thing that I discovered tho is that the design table will not actually update unless the external spreadsheet is open my problem is that when I try to use the macro to open the spreadsheet the design table does not update....only if I open the spreadsheet either through Excel or opening it from a browser window. I am using Application.FileDialog to select the file and put it in a variable then open it using Workbooks.open(). I know that FileDialog doesn't oopen a file but only allows it to be selected. I tried to use GetOpenFilename but I was unable to change the directory that the browser window opens in even when I used ChDrive and then ChDir. I am just learning VBA so please forgive my ignorance. Any help would be appreciated. Here is my code for reference
Option Explicit
Dim swApp           As SldWorks.SldWorks
Dim Part            As SldWorks.ModelDoc2
Dim newLink         As Variant
Dim currentLink     As Variant
Dim designTable     As SldWorks.designTable
Dim xlApp           As Excel.Application
Dim LayoutApp       As Excel.Application
Dim xlWS            As Excel.Worksheet
Dim xlWB            As Excel.Workbook
Dim Layout          As Excel.Workbook
Dim link            As String
Dim fileName        As String
Dim workingDir      As String
Dim swFrame         As SldWorks.Frame
Dim vWindows        As Variant
Dim swDocXt         As SldWorks.ModelDocExtension
Dim SelectedFile    As String
Set swApp = _
Application.SldWorks
Set xlApp = _
New Excel.Application
Set LayoutApp = _
LayoutApp.Visible = True
'Get current working directory
workingDir = CurDir$
With LayoutApp.Application.FileDialog(msoFileDialogFilePicker)
    .InitialFileName = workingDir
    .AllowMultiSelect = False
    .Title = "Select Spreadsheet to Open"
    .Filters.Add "Excel Files Only", "*.xlsx"
    If .Show = -1 Then
        'ok clicked
        SelectedFile = .SelectedItems(1)
        Set Layout = LayoutApp.Workbooks.Open(SelectedFile)
        Layout.Activate
        'MsgBox SelectedFile
    Else
        'cancel clicked
End With
'If SelectedFile = "" Then
'    End Sub
'Else
    Set swFrame = swApp.Frame
    vWindows = swFrame.ModelWindows
    If Not IsEmpty(vWindows) Then
        Dim i As Integer
            For i = 0 To UBound(vWindows)
                Dim win As ModelWindow
                Set win = vWindows(i)
                Set Part = swApp.ActiveDoc
                Set swDocXt = Part.Extension
                If swDocXt.HasDesignTable = False Then
                    Part.Save
                    swApp.CloseDoc Part.GetTitle()
                Else
                    Set designTable = Part.GetDesignTable
                    designTable.EditFeature
                    designTable.LinkToFile = False
                    designTable.UpdateFeature
                    designTable.Attach
                    Set xlWS = designTable.Worksheet
                    Set xlWB = designTable.Worksheet.Parent
                    'Get current links to external Excel Spreadsheet
                    currentLink = xlWB.LinkSources(xlExcelLinks)
                    link = Join(currentLink)
                    fileName = Mid(link, InStrRev(link, "\"))
                    'Get the current working directory and add the filename the link will be updated to
                    newLink = workingDir & fileName
                    If StrComp(link, newLink, vbTextCompare) = 0 Then
                        'MsgBox "Link Source is up to date"
                    Else
                        'Update Design Table link to external spreadsheet
                        xlWB.ChangeLink link, newLink, xlLinkTypeExcelLinks
                    Part.CloseFamilyTable
                    Part.Save
            Next
'End If
