I have naming system for Parts, which is for example P01C1, P01C2 etc.
How can I batch rename all file-names of Parts in that kind of way and keep references.
There is many programs that can rename bunch different files into this order (even Windows Explorer), but if I use them I will loose all references, is there is any correct way to do this in SolidWorks environment?
i found a way. I'm using this macro:
2012 SOLIDWORKS API Help - Pack and Go an Assembly (VBA)
This macro saves as Pack and Go with renaming all files. All you need to put whatever text you need to prefix or suffix.
