Dear all,
For some specific application, i need to place/stack parts in a row. These parts are very complicated parts (car panels to be specific).
Now, i would like to have a option to measure the minimal distance between two of these panels, anywhere it is.
I know the 'Measure' feature, and in fact is does the job quite well, despite the fact that now i have to say where to measure. So, i manually look for a spot where it seems likely to me to be the closest call in touching each other) and then manually measure the distance between those two points.
In fact, if i could select the whole part, and the whole other part, and the measure tool could give me the smallest distance/clearance between these two parts, me problem would be solved.
To make it all a bit clearer, i made a schematic example. Offcourse, in this example it's quite easy to see the smallest clearance distance. But, i want it to be defined automatically by selecting part 1 and part 2, instead of the two point i ( ! ) think are the "closest call."
Well, i'm looking forward to hear your solutions.
By the way, i'm running Solidworks 2016 Standard edition.
Thanks in advance,
Arno
I am not sure if you are looking for a macro, however below are some simple steps.
Step 1: User Selection Filter and Set it to Bodies
Step 2: Set the Measure Tool to "Measure Minimum Distance"
Step 3: Select the 2 Parts between which the Minimum Distance has to be calculated
Hope this helps.
Cheers
