I have Solidworks on Windows 10.
After installing SolidWorks, I went to Tools clicked on Xpress Products,
it loadedc and put a tab onto the Task Pane but there is no information in the SimulationXpress
Wizard.
Also, when in the sketch mode I tried to make relationships between two dimensions by
clicking on the dimension to open the Modify Box and then clicked onto the dimension
I wanted it related to, something like D1@Sketch1 should have populated into the
dimension box, but instead only the actual dimension was entered into the dimension
window. There is no (sigma sign) S on my toolbars.
I can access the Equations, Global Variables, and Dimension window,
but again I can not create any equation relationships.
I contacted Studica, where I ordered the program, about the problems I am having,
they suggested to uninstall and reinstall the program, to check the update to see if
KB3072630 was on my computer, I scanned the update file and did not find
KB3072630 update listed. I did uninstall and re-installed the program but I am having
the same problems, after several calls Studica suggested that I find a forum
since they have no technical support.
So my question is, is there a fix to resolve this issue?
Thanks Jim
