I can't get reference any drawing from attached part. I create "make drawing from part", i place some view in drawing and save. After I try to "open drawing" in part and ıt can't find the drawing file. I assume it depends about template. Could you please any suggestion for connect a drawing this part?
Serkan,
What version of SolidWorks are you using? I assume it is SolidWorks 2016 because when I open your file it says future version in the tree.
I am able to create a drawing with different views and save. However, I also get empty drawing views when I reopen the drawing. My work around is to create an assembly of your part and save. Then create a drawing from the assembly.
